Hi All, warning code LF on ideal icos boiler
26 Nov 2006
Norfolk
can you help me out, currently at work, mate has a very cold house has a 3 yr old ideal icos hx boiler he has warning sign LF on the boiler, when when he attempts to fire the boiler up the systems area as follows
there is is a large rumbling noise, followed by a louder crashing noise before it cycles through again
this happens about 3 times then the LF warning shows again
any suggestions
been really cold around our area
?? condensate problems
any ideas would be appreciated
many thanks Dave :(
went to same boiler yesterday where condense pipe went into 3in downspout which had frozen at the bottom. as the snow in the gutter melted , it filled the pipe and back up the condense and filled the boiler.water flooding out of boiler , water in gas valve.LF code showing.i would check your condense first , then gas valve and ignition probe needs checking by an rgi.
Is this something that I can do rather tan call someone out. I am a moderate DIYER with no boiler experience at all. Cleaning this condesate thing sounds simple.
Can anyone post a really simple step by step instructions??
Please!!! Its freezing
Hi there,
Go outside and isung either a hair dryer or kettles of boiling water defrost the condensate pipe.
Rico
