My hi flow 400 was fitted when my house was new, and is now 11 years old, in general it has been OK with no major issues
But i have had the same issue for a good few years now and that is noise when the hot water side kicks in from cold, ie morning start up, it has a sound best decribed as a 'creaking ship' and this happens for about 2-3 minutes, it makes a noise then goes quiet in cycles of about 30 seconds, the noise slowly reduces and then goes away.
system pressure is OK, Serviced quite regularly until my plumber went awol
Its had the pressure vessel replaced as it got water in the 'air side' , its had conditioner in the system from new.
It had a mysterious slow leak which turned out to be the washer /seal in the connector from the pump to the main heat exchanger.
But the noise is a personal thing now, as a mechanical engineer i am tyring to put some logic to it
If i was a betting man i would guess that either the hot water heat exchanger or the main one was clogging up and the noise i hear seems to be similar to a cavitation noise
as the more i increase the system pressure the less noisy it becomes, for a while and then starts again but i am getting towards two bar and its still noisy, anyone had the same .
Had a few plumbers look at it but they just changed things without any improvement , spoke to worcester bosh, they suggested the small bypass line blockage, checked that OK , and the water filter in the valve block , all Ok
any ideas
any ideas
