I've been looking into available products for roof insulation and all the regular ones are seemingly in the 0.02W/mK range. I was excited to come across Optim-R at .007 but am I correct thinking these are fragile vacuum units i.e. a nail through will ruin it?
Our roof design is solid boarded 18mm spruce, for typical garden use they simply supply shingles which are nailed on.
If you want to insulate they recommend a hot-roof design for condensation reasons. Up to 50mm insulation simply nail the shingles onto the board using 60mm clout nails, if you need more than that (which you surely will since the BR minimum roof value is .2W/m2 implying 100mm insulation) then the suggestion is to lay the insulation, build a frame on top using OSB or similar, add a DPM then nail shingles onto this outer frame (or something like that I'm regurgitating what I remember a builder saying). Both these options are fairly commonly used on these cabins, apparently.
So I wondered if there are any materials out there which are ultra-performing but rigid foam type construction suitable for this purpose? I am guessing not, at least at any affordable price?
I had also considered a hybrid approach - 50mm external insulation then some between the purlins as well. Purlins are approx 145 deep so quite a bit of space. We'd prefer to keep the inside open for cosmetic reasons, not sure which compromise is preferable.
Guy doing it has experience as a roofer and carpenter, seems to prefer the hot-roof option with lots of insulation outside. Does that seem reasonable?
