Swmbo wanted a fancy mirror, full length, in the hallway. Normally I send her away to allow me to fit it in peace because she can be distracting.
I couldn't fit the mirror against the skirting board because there was a plug socket in the way. So we elected to align the bottom of the mirror six inches above the skirting board.
I made the relevant marks at the bottom and drew a line with the spirit level so it was perfectly horizontal. Off this line, I measured up 1750mm and made marks on the wallpaper.
What did I do next? Get distracted by swmbo and then start drilling into those marks! They should have been 354mm apart. They were 450mm apart. Drilled one hole into brick. Drilled a second hole and felt the brick crumbling away. Only after I put the drill down did I realise my error. I sent swmbo away without mentioning anything.
After a few hasty measurements, I happily drilled holes in the correct places, put the rawlplugs up, screws in, and (eventually, with the help of some plunger type tools) lifted the mirror and fitted it in place. Old drill points were hidden by the mirror. Thankfully.
