I've an off-cut from a solid oak table-top I'd quite like to use as a shelf; it's 1m long, about 20cm deep, and the wood is about 4cm thick, so it's quite a hefty bit of wood.
I'd like it to be quite slick and was wondering about using some sort of hidden/invisible bracket rather than normal under-shelf brackets. A google search shows things like this exist:
But I'm a bit worried this would increase the torque applied to the wall, which is a modern internal wall (thick plasterboard on a 'wire' frame) so no bricks or wooden beams. With the shelf being heavy to begin with, is this a bad idea?
