I am doing some kitchen remodeling. The cooker control switch is mounted at 1.2m high on the wall, 0.3m horizontally from the 0.6m wide free standing electric cooker. The 6mm2 cable to the switch is buried in the solid wall, while the 6mm2 cable from the switch to the cooker is surface mounted. To make it look tidier, I'd like to bury the cable from the switch into the wall, and put in a flush mounted cooker connection unit for it to connect into.
Question.
Can I take the shortest horizontal/vertical route, across (0.5m) and down (0.75m) or down and across, or would you recommend I take the cable vertically all the way to the ceiling (up 1.2m), through the ceiling (across 0.5m) and all the way down again (down 2m). The floor is solid so running a cable under floor boards is not an option. Also what should I use to protect the cable, oval conduit or protective channel, and PVC or Steel?
Question.
