I am planning to install a windowsill, most likely made with square-profile pine windowsill board (if such a thing exists) or if not, from my trusty friend timber board.
I would like to ensure it is firmly fixed to the blockword underneath (there is currently no sill installed). This is easy if you want to paint the sill, just use screws and plugs, sink the heads and fill before painting. However, I would like to maintain the wood finish and use varnish. Obviously this makes filling the holes a little trickier. I don't want to use the plastic-wood style filler in such a prominent location, so I was planning to sink the screws down a centimetre or so into the wood, and use a piece of dowelling to fill the hole.
Is there a better way to do this? The main problem I can see with my plan is ensuring the wooden "plugs" are neither proud nor recessed into the sill (even a milimetre either way might end up looking dodgy). I guess if they are within a milimetre, and proud, then I can sand them.
Any suggestions?
Any suggestions?
