I've just done /doing mine and had the same thing. The problem I had was that the bathroom wall is circa 1680mm so a "standard" 1700 bath meant channeling just to make it fit. There was not much hope of making it fit with aquapanel dotted and dabbed
I'm a DIYer so my method is by no means from the plumbing bible but...
I decided from the start that I would be using a surface mount mixer - my folks installed a brand new concealed mixer in a new stud wall, complete with rear service access but due to a mis-communication it got tiled over. 1 week later the brand new valve predictably went mammory verticales causing much bemusement
So I will be using something like
THIS
This means that you'll need wallmount elbows to attach the shower.
I channeled out a letterbox in the wall to a depth of about 1.5" by about 3" by maybe 7" to mount the elbows in. Then I chaneled out two vertical slots for the pipes to the elbows probably about 1.5" square down to below bath level
I then screwed the elbows on (also using epoxy adhesive too lol), saddled 15mm plastic pipes into the vertical channels then filled the channels up with expanding foam back to wall surface level. I hope the plastic will prevent any corrosion problems and the foam will stop any expansion/contraction issues. The compressions on the elbows are assembled with ptfe + fernox lsx + several yards of knuckle skin religeously sacrificed to the fickle gods of plumbing over the last couple of weeks
This has now been pressure tested for a week with not even a drip. Tiler is coming next week to seal it all up! I've also tried to figure it out so that a single tile will cover the elbows should they need service
Fingers crossed
You can see the final result behind the bath in this rather poor photo
