I bought a high pressure mixer tap recently.
Can I connect it to the pump?
but then I assume there will be a short on & off on the pump everytime the tap is used + a vibration noise :S Will this harms the pump's life?
Alternative is I guess to use the Cold from the Main, and keep the Hot from the hot cylinder, but there will be a pressure difference between the two. If so what should I need to fit?
any suggestion would be great, Many Thanks!
