High gloss finish on a door
17 May 2005
Fife
Hi
Anyone point me in the right direction?
Can i produce a high gloss finish on a wooden door.?
It will be a bathroom door.
Ta :p
f49h said:
Hi
Ta :p
Of course you can....given the right tools and materials.
How about some details first of the door itself....is it flush or panelled?....has it been painted before?....what with? if so..whats the surface like?....
There are too many permutations to go through for every scenario...
Lets have some details first
Hi
The door is a panel door. Pine I think or a soft wood.
It hasn't been painted, but has a light coat of varnish
It will probably need a good thrashing with a sander.
Hope the info is helpful.
Ok then....remove all the fittings first....but keep the spindle in your pocket in case the door slams shut while your in the room.
A 'good thrashing'...it certainly will as paint doesnt take at all well to varnish.
After sanding the first thing you will need to do is get some knoting over the knots to prevent bleeding.
then give the whole door a coat of some sort of melamine primer...id suggest Dulux super grip......i use it all the time..its great for problem surfaces
Next.....you need to give the door a good sanding down, this is crutial, and you must do it in between each coat
Once sanded and dusted off then give the door a good coat of undercoat.....and sand again with wet and dry paper to remove the brush marks...
Then i would suggest two coats of gloss...again, after allowing the first coat to dry....lightly sand with wet and dry paper...fine grade...(400)
The reason for two coats of gloss.....the smoother the surfaces, the higher the light reflectance will be....the shinier the finish.
The darker the colour......the deeper the shine...
Dont use one coat gloss's they do not have such a deep sheen.
Invest in a good quality brush.....such as a hamilton perfection...expensive but worth it in the long run.......certainly avoid the '25 brushes for a fiver' jobs.....the card they are fixed to is worth more than the brushes.!
Tip:- when using wet an dry....leave it to soak for five mins in a bucket of warm water with a dash of washing up liquid first.
The washing up liquid in the water will also help the water stay on the surface of the door when you wet it prior to rubbing down......keep it rinsed and dont allow the abrasive paper to clog.
Wear gloves.....wet and dry paper cuts through your skin very easily and you wont notice it until its too late....and you will have taken a few layers of skin of! :cry:
Hi
Cheers for that ,
I let you know how it goes
Use a foam roller to apply the gloss, gives a better finish than brushing IMO.
