high output radiator help
14 Feb 2013
Anglesey
Hi. Im looking for a high output radiator for my lounge. I want to heat the 6.2m wide x 4.2m long x 2.4m high lounge with a single radiator. The calulators say i need around 10-12000 btu. The area to place it is a max 180cm long and 80cm high. So far the only one i have come up with is the stelrad K3. But its a triple and im not sure how far that will stick out. Any other radiators to look at or tips on this? thanks.
Unfortunately the problem is that you only want one rad tha best place for it is under a window
this is to stop the cold fall from the glass if you put a rad on the back wall oppersite the window
you create a draft so unless you have a massive space for a double rad you're stuck with a
triple rad but it really needs to be under a window
