Hope someone can help with this newbie question... we recently just had a bathroom refurbished and we chose taps that recommend minimum 0.5bar pressure. We have a gravity fed water system so estimate we have 0.2 bar pressure. The taps run slowly and take about 15 minutes to run a hot bath. The basin taps also run slow. Both the bath and basin taps are mixers.
We have a shower which has a water pump to give adequate pressure at the shower head. My question is whether we could redo the plumbing so that all the taps are fed from the pump, instead of having the pump just feed to the shower. It's unlikely that anyone would be running more than 1 tap at a time, so in theory this would work but is it common practise to feed an entire bathroom off of a shower pump?
The alternative is (1) buy new low-pressure taps, or (2) convert to an unvented water system. But we can't find any low pressure taps we like, and converting the whole water system would be a huge job.
Any thoughts much appreciated!
