- Joined
- 27 Jan 2008
- Messages
- 24,903
- Reaction score
- 2,877
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have a Pentax K10D but the hot shoe flash gun I use is quite old so was looking at replacing it with one which has the extra contact to get full dedication with camera. When looking at new flash guns there is a huge jump in price to get High Speed Flash and wireless function and I wonder if worth the extra money? I have to date only had one picture where the slow sync speed was a problem. A water fall and natural light caused trails on each droplet. Some day I will return and try a night shot. However it seems the high speed flash will remove this problem and so may be worth the extra money. So has any one tried it. I include an explanation as I will guess many readers will have never have heard of it so may not understand the question.
This allows one to use the flash in combination with shutter speeds faster than the camera's sync speed, which in current Pentax models is 1/180th of a second. At shutter speeds exceeding that, there's never actually any time when the entire sensor is exposed at once: there's just a fast-traveling slit between the front and rear shutters. HSS works by creating many very fast pulses rather than one bright flash, so the tradeoff is reduced power. This isn't necessary (in fact, quite the contrary) for freezing motion — for that, you need to look at the actual flash duration (which is generally much, much shorter than the shutter speed).
At the moment I use a Vivitar 3500 on camera (low hot shoe voltage) and another old high voltage flash gun with a flash triggered remote. Since I also use some old lenses it is used in the main on manual camera settings but although the sensor will change the output of the flash there is no manual setting. Since I want off camera flash my options are to buy a very cheap low output flash to use purely to trigger the other flashes or get an expensive one with all bells and whistles.
So interested to hear what others have found.
