High temperature condensate pump
14 Jul 2016
There are a few higher temperature condensate boiler pumps available that can take the pressure relief pipe discharge as well as condensate. Anyone had experience of them?
BOILER PRV DISCHARGE COMPATIBLE
• Able to easily handle high temperature (≤90°C) inflows for up to 5 minutes, all models in the CONLIFT range have been tested and confirmed suitable for connection to the discharge from a domestic (<40kW) condensing boiler Pressure Relief Valve (PRV)
https://uk.grundfos.com/content/dam/UK/Brochure/Grundfos_Conlift1_LS-Jun17.pdf
I think all can, if not most. If the pump fails the boiler is locked out. The Grundfos Conlift can do pressure discharge and condensate. It is quite cheap for what it does, about £52-57, with most that do both being upwards of £200.
