highflow 440 - how to open?
9 Oct 2011
Bristol
Probably a simple question to most of you - but how do you open the cabinet of the Worcester highflow 440 - manual says out then up but there seems to be a trick to it.
Lift the complete front case upwards, pull the top towards you and lift off the bottom.
Hope that helps
Thanks. But there is less than a millimetre of space above the entire front, doesn't feel like there is anywhere to move. It seems like the instructions for our old model 400, the design has been "improved" since then.
No it's definitely the instructions for the 440
What's on top of the front casing that won't allow it to be moved up ?
No need to lift the front case. Grip the top of the front panel and pull towards you to disengage the spring clips and then lift off the bottom lugs.
Now that you will have opened the front I am curious as to what you you will be doing inside!
Tony
Thanks 45yearsagasman, did the trick (pull = insert large flat-head screwdriver between the front panel and side, and twist). Thanks others for your time/interest. Just adding some more water to the system, pressure is a bit low.
