Hinged shower door or sliding?
11 Jun 2012
Hi, I am in the process of getting a new shower enclosure fitted, theres a particular one the fitter recommended, which does look nice.
You can get the door either hinged or sliding, and I wondered if one was better than the other?
My thinking is, would a hinged be easier to keep clean and maintain, over time sliding can stick a bit or not be as smooth as they were?
Would the seal to keep water out ultimately be the same, or would one be better than the other?
The 2 I am looking at are:
Enclosure
That is the sliding, the hinged is the same design, but the hinge is in the middle and closed to the side.
James
Just finished installing our sliding version of a similar brand. The opening for you to get into the enclosure is wider on the sliding version than the hinged one when opened, so easier access. I also had concerns about water dripping from the door of the hinged. type when the door is open as you exit the enclosure.
