Hinging two fabric covered panels together?
4 Jun 2011
Bristol
hi there,
I am fitting out a camper van and the bed is constructed of 18mm ply sheets hinged together in the middle. The ply sheets are covered in 3mm fabric and I want to hinge them together so they fold closed.
the problem is, with normal hinges they will need to be packed out to raise them up so that there is enough clearance for the fabric to ensure the panels go together evenly.
Ideally I'd like to use a hinge with some additional clearance 'built in' between the plates and the hinge itself so I can then recess the hinge plates into the ply whilst leaving enough space for the fabric so the sheets fold together cleanly.
anyone know of a sort of hinge that will do this? I imagine the hinge itself would need to be offset from the plate in some way...
cheers.
Put hinges on the face edge they will be more secure and not require spacing
hi limbo, im a caravan fitter, our bed boards are the same as yours, ply covered in 3mm poly/material, we latley have just been using butt hinges 3-2 1/2 inch hinges to cover about 600mm, all we do is put the boards side by side and screw the hinges to the face side of the boards, the hinges sink into the fabric and seem flush.
really is as simple as that :),
hope this helps
tom
