- Joined
- 26 Jan 2013
- Messages
- 3
- Reaction score
- 0
- Country
Last night I started hearing a hissing noise coming from the area between my kitchen sink, dishwasher and the wall the dishwasher backs against. There's no leak under the sink. No leak under the dishwasher. I turned the water supply off to the house and the hissing stops. I'm on a concrete slab. I turned off the water to the two toilets because one has a defective valve or something in the tank and sometimes sprays a little water. Once I turned them off and went out to the meter I stood for 10 minutes and watched. The little triangle didn't budge. The red "hour hand" didn't budge. I cut a hole in the drywall and by dumb luck I cut right where the drain pipe drops down and just to the right of where the copper water lines drop down. I can see the wood footer of the wall and I can see a bit of the concrete. No sign of water. There's no dampness on the floor or in the wall. The only sign of any issue is that hissing noise. I am no plumber. I'm a single 42 year old woman. I sure can't afford to have walls and floors and slab torn up. If I had a leak, wouldn't the meter move??
