Hi everyone,
I received a higher than usual water bill last week. I can now hear a hissing sound in the cold mains pipe on the ground floor of a 1970's terraced townhouse (had to switch off several appliances, like freezer and NAS/hard disks, to sense this noise). There is no history of leaks inside the house or outside during my ownership the last 10 years and I would say the property has been maintained well.
The house is dry all over, e.g.:
- checked all taps,
- valves,
- toilet flushes,
- loft tank, etc.
No signs of leak anywhere, inside or outside the property, no damp walls/floors, absolutely nothing and the water flow and pressure seem OK. That's during normal occupancy for a family of 4.
I have consumed many related and very useful threads in this forum which advised to do further checks with the stop valves:
- With all appliances off at home the water meter is active.
- When I switch off the home stop cock (right at the entrance on a straight line, ~25ft from the Thames Water meter), I can still hear the hissing noise, but I have the feeling it faints a little. The meter still shows activity.
- When I switch off the valve at the pavement, the sound is gone completely. The meter still clocks, of course much lesser now, but it doesn't fully stop as I would have expected.
Would this indicate some sort of leak on the service pipes under the driveway (laid between the meter and the home stop cock)? If there is a leak, where does this water go? There are no signs of puddles, or anything else on the driveway to indicate a leak... This is all very puzzling.
I would appreciate further advice.
Many thanks,
Stan.
- checked all taps,
- valves,
- toilet flushes,
- loft tank, etc.
Many thanks,
Stan.
