is 3 core hituf cable acceptable for use as a permanent supply to my shed from my cu (clipped directly along the top side of the wall down the gaden) with no additional protection. i believe it is just double checking. easier to isolate than the swa.
Pretty much, yeah. Look at photos of it stripped back (one on TLC). It has an extra layer (think its XLPE but still not steel armour - steel armour has XLPE insulation)
that's a rather sweeping statement..
hituf is perfectly ok to wire down to a shed.. PROVIDING it's in an earthed metalic duct... sich as steel conduit..
