Hello
after buying Hive light bulbs with the little hub etc, I quite fancy connecting the boiler up too, so bought a Hive Active Heating Multizone....
I don't own any other heating kit from Hive. Will the thing I bought work without buying any other Hive heating "kit".
The reason I'm worried is that on the side of the box (that i seen after opening everything) it states
In order to have Hive Multizone you will have need to purchase Hive Active Heating™ which contains a thermostat, receiver and Hub. For each additional Hive Multizone kit you will receive an additional thermostat and receiver.
All i want is a wifi thermostat that's controllable from a web app, my house is tiny so not bothered about "mulitple zones etc"....did I buy the wrong thing, or can i just wire this up an it should just work?
thanks
thanks
