New to the forum and was after a bit of advice. I currently have a BG UP2 programmer controlling a Bosch greenstar condenser boiler. The room stat is a poorly sited (opposite a radiator) honeywell DT90e, two wires with the neutral blanked and taped in the back of the pattress on the wall (plasterboard).
I understand that the receiver can be a direct replacement for the programmer, the controller can be sited as I see fit, either fixed to the wall or floating around the house on a stand and there is a bridge unit that is plugged into the router.
My query is about the removal of the roomstat. I am thinking of linking the the wires in the pattress and leaving them in situ. I will then blank off the pattress with an blanking plate so its available if we move and I can take the hive system out.
Is this the done thing? I cant find a wiring centre to disconnect the roomstat from so I am guessing they go back to the boiler or programmer and that is where my 'expertise' definitely comes to an end. The wiring at the back of the programmer is like a birds nest. If the consensus is that it should be disconnected at the boiler/ programmer then I'll get a trade in!
