Hello,
I'm after some advice regarding what may be wrong with either the wiring or the Hive system.
Like many people I bought a Hive Active Home on Amazon Prime day.
One of the reasons I went for Hive was that is should have been a simple case of remove the old programmer & clip on the new Hive.
I disconnected the old wireless Digistat SCR, linked the wires at 2 & 3 on the LWC1. Set everything up & started to test it all worked. Hot water not a problem, heating however causes both green lights on the receiver for hot water and heating to come on & the Y valve to go to mid point.
I checked that the hot water wasn't set to be on & looked at the wiring several times & could see what the issue was. I started to feed another wire to the receiver back plate for connector 2 (heating off) in case it needed it to stop a back feed. But there was no point to connect it to in the LWC1, several posts I found online claim I don't need it for my system. The next thing I did was remove wire from connection 3 from hot water off at the LWC1 but that made no difference.
I'm getting stumped now & looking for more advice if someone can help me please. Sorry if I waffled on a bit but hopefully I've given enough info. Here are some pictures of the system to hopefully help someone find the issue.
Thanks.
https://ibb.co/caXjxv
https://ibb.co/gE5hja
https://ibb.co/jQWoPa
Thanks.
