Hi
I have a problem with my Halstead Finest Gold boiler.
The CH works fine although at the moment it is turned off (summer)
The Hot Water when demanded gets hot but then the saftey lockout LED comes on and obviously the water temp reduces back to cold.
I have tried reducing the temperature on the DOMESTIC HOT WATER
CONTROL switch right to minimum. (which worked for a while but now does not)
The overheat thermostat reset button on the underside left of the boiler does not click out so i am assuming it is not that ??.
The fan and pump are running as i can hear them when i switch the mains electric on and off to reset after lockout.
HELP
anyone got any idea??
HELP
