i have bought a elec hob and double oven to replace a gas hob and single elec oven
at the moment the single oven is fed by a 6mm cable with 32 amp mcb
will i have to upgrade the mcb or is that ok ?
in instructions it says " where a hob is fitted adjacent to an oven then a 45 amp D P control switch should be used to feed both units via seperate rated cables " so does that mean i feed both units from the one D P switch using probably 4 mm cable ?
thank you for your help
ratings for oven is max load 5.3 k w
hob... 50-60 hz 5700 w
