Apologies if repeating a subject that seems quite frequent in this forum but I cannot quite put it all together.
I need some help to understand what is needed for connecting an electrical hob and oven. I have the hob but still need to buy an oven.
My hob is labeled 7.3kW and currently connected on a dedicated circuit. From the Consumer Unit where there is a 45A fuse a 6mm T&E cable goes to a 45A DP Switch with a 13A Socket. The Hob is then connected from there. Overall the cable is no more than 10m.
So my questions are,
1. Can I connect the Oven directly to this circuit with a cable into the same 45A DP switch?
2. What is the highest power usage my oven can have for this circuit combined with my Hob.
3. Can I connect the Oven to a “normal” circuit i.e. not the dedicated Hob circuit?
Thanks.
Thanks.
