Is it ok to use a flexible tap hose (the stainless steel braided type) to fit onto a hob. I have a gas isolating valve and want to fit the hose to it using 15mm and half inch onto the hob. I would use gas ptfe tape. bearing in mind that these hoses can work up to 15 bar and the gas pressure is millibars is there any reason that these hoses cannot be used?
It would be a nightmare to plumb it in using copper and a flexible hose of 500mm would make my job alot easier ( this is in my own home).
thanks in adv ance
scott
thanks in adv ance
scott
