I'm not sure if this should be here or building, but as it involves plasterboard, I am sure you guys will have a useful answer.
Starting to put the house back together after the dry rot issue and removal of the old lathe and plaster ceiling.
Part of the room has a pitched ceiling formed by the roof rafters. Thanks to some previous advice on here, I have insulated between the rafters (ensuring thatthere is a suitable minimum air gap to keep the coold airspace) and will be putting insulation across the rafters to stop the thermal bridging and save some energy.
But the question is is there and easy way to keep the celotex on the pitched roof prior to fitting the plasterboard?
