holding tiles in place, how? ( top of window 'reveal')
21 Oct 2003
I've just about finished re-tiling my bathroom, just the tricky bits to go!
Where the window is set in the wall ( window reveal?) I have tiled the window ledge and sides, but how do I hold the tiles in place on the underside of the lintel, until the adhesive goes off?
How do I stop the tiles on the flat piece of wall above the lintel from slipping as well. Should I use 'gaffer tape' as refered to in gcol's sticky at the start of this forum section?
I have used masking tape, I have also had to prop up with a strip of wood.
Both methods were ok, I prefered the masking tape as you could do a visual a bit later on.
if you have someone you dont like, they can hold it in place till its set, i have done this in the past! :LOL: :LOL:
Gaffer tape and then a wooden prop if the tiles are heavy. I have used a bottle jack in the past with timber struts, makes for easier adjustment.
no not meant personally!
The sticky was talking about tiling beneath a row of fixed tiles, not upsidedown, under a window reveal.
I couldn't see 'what' to stick 'where' with the gaffa tape, as it would all be upside down and likely to drop off!.
I use tape and a prop!
