Would any body know of an easy way of repairing a hole in a soil pipe. Its cast iron. Is there a way of repairing this as its on a sweept tee? Will add photos and a better description tomorrow but getting S**t off the missus at the moment LITERALLY!!!!
Cut a piece of plastic soil pipe larger than the hole Clean the patch area off and then get your silicone out along with a handfull of tie wraps or some flashband.
Then paint it so it doesnt look totally naff.
Welding cast iron is not an easy task so unless you know an expert at it don't bother.
You could always renew the stack. It ain't too bad a job if its external. That is assuming your house isnt too high
If the hole has rusted from the inside then much of the pipe may be ready to fail as well.
To do a repair, rather than pay a lot for something new, I would just cut a small piece of copper sheet from an old cylinder and angle grind the area around the hole and then epoxy the copper onto the cast iron.
That would do a good repair at no additional cost as I already have standard epoxy.
