I woke up to two rooms with wet ceilings and walls today. A quick poke around in the attic and saw water was coming in around the chimney. Put my ladders up, tied them off and took the picture below.
https://images2.imgbox.com/88/b4/yolwAEWV_o.jpg
There's a hole in the lead flashing just before it tucks up into the apron around the brickwork.
What's the fastest way to fix this?
I can't wait 1 - 2 months for a roofer to come out. Ideally, I'd replace the lead with a continuous piece but that's a big job.
I have some strips of lead flashing I could cut to shape to cover the hole. Bash it into shape with a hammer. The hole is right on a bend, and at a low point, so water will sit on it.
I take it a regular propane blow torch is no good for welding the lead together (?) I see people on YT using very fine tip torches to weld lead. Seems to be a bit of an art. Too much heat and you creat another hole.
I could use lead sheet sealant under the patch. How big would the patch overlap need to be?
Thanks.
Thanks.
