I need to fill this hole, obviously I can't use just filler.
How would I do this please?
Many thanks.
If I could be bothered, I would use a hole cutter in a piece of wood of similar thickness, to make a close fitting plug that I could glue into the hole, then use filler before painting it.
a page out of The Sun screwed into a ball - then filler either side Bleedin antique furniture is made of Papier Mache - that`s wetted paper
Many thanks.
too late....If I could be bothered, I would use a hole cutter in a piece of wood of similar thickness, to make a close fitting plug that I could glue into the hole, then use filler before painting it.
