hole in plastic guttering
30 Apr 2009
Hi
One leak from plastic guttering....just at a corner joint.How best to fix it?
Buy a new corner ;)
LOL - someone must be thinking "Hmmmm why didn't I think of that?"
Easy to buy a new corner but how to fit it?? Easy for some I'm sure.
Have bought a tube of silicone and will try option 1!
Many thanks
the fittings are clipped together! you should unclip the corner to clean the joint before applying the sealant.
Personaly i would'nt silicone it if there is a hole in it just take it off and the majority will have the make stamped onto it and phone around to see which builder or plumbing stockists deal in them.Also some times the rubber seals perish after time and with some makes these are easy to replace and will cost less than a tube of silicone.
