Dear all,
Help wanted for a never before worked with plaster person!!
I am wanting to get the below fire installed but before then I need some plastering doing around the opening of the Hole in the wall fireplace.
http://bit.ly/1L6YZKd
The opening needs to be 415mm W x 570mm H
The opening is currently 470mm W x 560mm H
The plastering will need to be both sides to square up the opening.
Below is also a picture of the fireplace as it is now.
I have heard that the fireplace surround can have plasterboard placed around it then skimmed with '3in1' plaster?? Is this safe, due to heat etc?
I am after the quickest way to get this done so I can get the new fitted as soon as possible..
Many thanks all....
Mark
Many thanks all....
Mark
