Hi all.
A friend has bought a marble washbasin and wants to build its own worktop and cabinet underneath for the storage of towels. My question is when drilling the hole in the worktop to accommodate the basin waste outlet should the hole in the worktop be exactly the same dimension as the outlet so that when i tighten the back nut, from underneath the worktop, it grips on the worktop holding the washbasin in place or should the hole be bigger allowing the back nut to go through the worktop when tightening it up ( but then if somebody pushes the basin it will be easily displaced)? BTW i should mention that he wants the whole washbasin to rest on the worktop surface. Thank you 4 your advice.
