Thanks very much judging by some of the responses I suppose what I should have asked instead is.
"For the Speedfit Tank Connector fitting to form a watertight seal do I need to make a hole exactly the diameter of the thread or do I get a few mm grace. The thread measures 36mm so does it seem likely that i'll be able to get away with a 38mm hole or do Speedfit connectors require more precision?"
From wiggikins answer it seems like it might work out ok?
