I have concerns about all the holes that have been drilled into the joists in our new extension. My understanding from documents like this (North Herts Council Building Control Technical Guidance Note No. 22 Notching Of Joists) is that holes should be:
The holes in my joists are not within the permitted area. In the photos below, I have use red tape to mark 0.25 and 0.4 the span. There is one hole right in the center of the span, with a cable hanging down out of it (this has 3 joist together).
Why have they drilled holes outside of the permitted zone? The document is from building control - it must carry some weight?
Joists: 218mm x 45mm
Span: 4060mm (from edge of RSJ to edge of wall bracket holding joist)
- Drilled into center line.
- Drilled between 0.25 - 0.4 the length of the span.
- The distance between holes should be greater than 3 x hole diameter.
- Hole diameters should be 0.25 x joist depth.
