I recently rented a holiday property that has a Worcester Heat Slave 9-24 combi boiler.I was informed by the landlord that the previous tenants had the boiler fail(pilot light extinguish) 8/9 times in the previous week.The landlord informed me that an engineer had looked at it and could find no fault.The landlord then showed me how to remove the outer cover of the boiler and relight it.Whilst I was in the property the boiler failed twice in two hours.No immersion heater was available to heat water and there was no other way to provide any heating.
A landlord's gas safety certificate from 1999 was the only paperwork provided with the boiler for the tenant.The certificate stated that there was an insufficient gas supply.
I was very unhappy with this situation and due to the habitability and safety problems I refused the let on the property.
I have contacted Worcester who told me that this Boiler is 20+ years old and is obsolete and needs replacement.A current gas certificate has now emerged and I am told that a pump was replaced on the boiler back in the Spring.
What would have caused the boiler to keep extinguishing?
What paperwork should a tenant be provided with before commencing a tenancy?
Was the boiler in a fit state to be continued to be operated by continually having to relight it?
