All of the sheds will have some sort of fixing for you, and some will work better than others. Screwfix 81956 is a typical example, but the important part of these is that the main part of the body - that is non collapsible - needs to be no longer than the thickness of the door panel.
The same applies to hollow wall anchors - 18266. one of the smallest ones is Toolstation 82447.
Personally I find that Homebase has a good variety of stock, and easy to see on the racks.
John
Thanks Burnerman - I'll take my pick from one of those. I just seem to have a vague recollection of packets with "hollow door fixings" written on then. Maybe I was dreaming
