Hi all,
I'm in the process of converting a car port into a garage and have discovered the ground under the poured concrete floor slab may have dropped.
The garage is 48 years old and is in an area susceptible to subsidence (big pine trees surrounding the house).
One half of the slab sounds hollow when hit with a hammer. I cut-away a section and removed the concrete. The slab is about 4 inches thick and sits on a damp-proof membrane, which is over a bed of loose gravel. There is no evidence of the slab cracking anywhere. The concrete is still resilient (difficult cut through and a ballache to break with the sledgehammer).
The house is a keeper so I would like to do this right, but I would also like to avoid disturbing the floor if possible. I plan to pour a latex screed over the floor and use it as a workshop.
Can anyone with experience of concrete floors tell me whether I can leave it alone, or whether I should be re-pouring it before I lay the screed?
[/URL][/img]
