- Joined
- 26 Jun 2014
- Messages
- 4
- Reaction score
- 0
- Country
OK,
I've got a rafter, joist, ridge and purlin roof. Gable end, standard pitch. The rafters are 3 x 2's, the purlins are massive 12 x 4 hunks. the span of the purlins is 5 metes the length eaves to eaves is 8 metres with a load bearing wall in the middle.
I noticed a tapered vertical crack developing between a first floor internal wall abutting an external wall. the ceiling has also got a crack where the external wall has pulled away from the plasterboard.
Having pulled off all the surrounding plaster and bathroom tiles I've discovered the external wall is bowing out from the centre of the external wall and has pulled away about 25mm from the internal wall. It has pulled out most at the wall plate height and tapers back in to the internal wall about 3 foot lower. the ridge of the roof appears, from the outside, to have sagged too
So I've clearly got some roof spreading going on.
I've re nailed all of the ceiling joist at the centre overlap and I've crawled into the eaves to have a look at how the rafters are attached to the joists and to my surprise I cannot find any trace of the rafters being originally nailed to the joists. In fact I can slide a saw between the rafters and joists and it slides in and out, up and down without any hindrance so I m pretty sure there are no nails there
the rafters have the normal 'birds mouth' cut to sit on the wall plate.
Is it normal not to have the rafters nailed to the joists? they surely must be attached somehow??? so perhaps the rafters are nailed through the top of them into the wall plate and the joists are perhaps also nailed into the wall plate and so the wall plate is the thing tying it all together albeit not very well!
There is a slight tapered twist movement in the purlins apparent in the mortar where they bed into the wall, nothing massive though only maybe a 1mm twist. I would have expected more given the amount the wall has bowed but maybe the rafters have just slipped off the purlins, again, if they are not nailed.
So in my mind I need to nail the rafter to the joists and create the triangles in each pair of rafters and joists to give the strength required to prevent deflection and strap the external wall back to the internal wall to tie it back together.
any other thoughts?
I'm particularly interested to know if its normal in roof construction not to nail the rafters to the joists and just nail them both to the wall plate as appears to be the case here.
cheers
any other thoughts?
cheers
