I moved into a house not long ago so I inherited an alarm system with problems. I have managed to get the parts I need including a brand new control system PCB (importantly with the default engineering code!), so I'm ready to put it right.
At my last house I modified my alarm system but I had the engineering code so it was easy. Now I'm a bit concerned about this one because I don't have the engineering code so I'm going to have to start by either isolating the power or by triggering the tamper switch on the control box which will obviously set off the alarm.
The internal alarms are one thing, but I really don't want to **** off my neighbours by having the external sounder going whilst I disconnect the control PCB. You see I'm paranoid that once having done that the sounder will still be going because it gets its power from elsewhere!
I don't really want to isolate the whole house power feed, so I need to know how to disable the external alarm.
Is it typical for external alarms to be mains-powered or are they usually d.c. powered from the control unit such that as long as I disconnect the board power and the back-up battery I'll be OK?
