If I DO manage one, anyone instrested in the designs?
not really, why try and re invent the wheel
as for how the sensors work it depends on what it is and what panel it is connected to
lets ignore how the sensor picks up in the first place (for ease)
origonaly there was one continious loop, if the loop was broken then an alarm condition is raised
some one realised one single pole loop was not enogh, becuse you can "bridge it" so any thing after the bridge wont be noticed
so they came up with double pole
one pole +ve
the other -ve
bridge the + to -
shorts out alarm condition raised
then some one came up with the idea of making the 2nd loop (-) 24 hour
and so it stayed for quite a number of years
then some one (a lot of people called some one isnt there?) came up with the idea of one loop with a resitor on the end
cut it or bridge it alarm condition is raised
but it still needed a 24 hour loop, so it didnt last long in the intruder alarm industy, but the Fire alarm industry adopted it, and still use it
then some one came up with the idea of 2 resistors
one "end of line" the panel must alaways see this, and a shunt resistor
when a device is closed it shorts the shunt resistor so the panel only sees the end of line resisitor
when the device detects something the panel sees both resistors and an alarm condition is raised
if the panel sees no resistor, be it shorted or cut, the panel goes into tamper (24 hours)
this last method is quite common since it means you can use a 4 core cable to power a detector and monitor its sate, be it normal, alarm or tamper
There have been various other "fads" mostly called biscuits (seriously)
the most popular was ADE's biscuits with 3 wires, followed by Scantronics biscuits with 7 wires (think it was 7)
Scantronic's ones you had to programme it to give it an identity, but it also had an output
ADE's one was easier to use but was limited to 30 biscuits
Both did very well but were considered a bit too complicated for most alarm engineers and now neither are in production and no spares, wichi is a pain because if you do find a sytem with 30 biscuits they could all be on 1, 4 core cable, whcih means a complete re wire
Still want to continue with your idea?
