home made consevatory
17 Feb 2007
Derbyshire
Hi all, hope some of you can shed a little light on a project i've got on, there is a lean to pitch roof extension/conservatory on the back of my house, it is around 20' x 5' it has 1 full height 1 on the 5' side the remainder is a dwarf wall and has single glassed wooden windows that are rotten to the main face and 1 side these windows go from the dwarf wall to what looks like the main roof beam, my questions are:
1) is the best way to replace these by propping the end window and the replacing that 1 first then remove the full face 1's either side of the door and door and prop the roof and then replace?
2) do i give the manufacures the external dimensions that i require?
3) on the corner that is all glass, do you get a corner post which you fit then attach the windows to that or do you fit window to window to form the corner? if so how do you attach the window together?
many thanks Bren.... :cry:
do you intend replacing like for like, i.e timber windows with single/double glazed units? or do you intend replacing it with pvcu?
is the masonry sound, is it twin skin and is it to remain the same?
Hi noseall,
No, the idea is to replace with pvcu, it is sigle skin and sound and is also to remain the same.
