I was just after some resources or advice for my home renovation project as far as TV AV goes.
I am just in the process of installing boxes and cutting chasing in the walls to take the required cabling. Power and lighting are done, but I have to do some research before I cut the amount of boxes for the TVs. As wall boxes are unsightly, especially at TV level, less is more, thus if there is a good wireless solution that would be better.
Desired: TV/ Freeview and Virgin/ Sky + Auxs at main TV in lounge. All boxes situated there, with additional TVs in bedroom 1 and 2 on the wall with no visible cables. I am fairly indifferent about wall mounting to be fair, but it saves about 1-2 ft of room space, so if they are going to go on the wall, I will go for a cable-free look. I would need to be able to controll the boxes on the main TV in the lounge via IR in rooms 2 and 3.
I am not realistically going to watch SAT in more than one room at a time, but it would be nice to have the freeview or DVD option simultaneously in bedrooms 1 and 2. Additionally, I am ditching everything that is not HDMI at this point.
I have seen HDMI wireless senders around for about £150-200 that allow you to send wireless to TV 2 and so on... I will opt for these as long as there are no general reception issues or common interference issues.
Otherwise, am I correct in thinking that I will need power, HDMI, Co-ax and sat to each additional TV? Or at least power, HDMI and coax.
Is there another solution?
I would take wireless based on ease and cost, but am prepared to fit cable in chasing if need be.
Is there a minimum distance from power that other cables need to be?
Is there a good online reference for all these scenarios; mine of which seems to be a common scenario.
