Hopefully someone can shed some light on this..
I have Triax TV/SAT/FM wall plates in three rooms of the house.. In the loft I have a TV antenna and an FM antenna.. These are connected to an Antiference (http://www.antiference.co.uk/distribution-amplifiers-0) amplifier to the UHF and VHF ports..
From the amplifier I feed the TV signal into a Triax TV/SAT combiner along with an LNB connection from the sat dish.. Then down to the wall plates..
The issue is that if the FM antenna is connected I loose a number of TV channels.. Specifically channels like BBC1.. In fact the first channel I can get is channel 11 "Pick"..
If I disconnect the FM antenna all TV channels work fine..
I have tried removing the combiner and the wall plates but still loose the channels when the FM antenna is connected..
Anyone have any ideas?
Thanks..
Thanks..
