- Joined
- 12 May 2009
- Messages
- 105
- Reaction score
- 1
- Country
has any of you guys used this product there is ultraseal before tiling and ultraseal after tiling then there is ultraseal plus. the ultra seal design basically can expand upto 15mm the plus only 10mm. basically its like 2 peices which can expand or contract therefore if there is movement in the bath or shower floor against the wall the seal wont break . the plus design i think is fixed to floor and wall using silcone where as the ultraseal after tile is stuck to the tile and floor using supplied adhesive tape. the ultra seal b4 tiling is the same as after tiling apart from the area that meet the wall is adhesivesed in so yes you need to fit proir to the bottom row of tiles.
i have few questions
im either going to the ultraseal plus or the ultraseal after tiling, the reason is incase i decide to remove in future it wont affect the tiles. but which is better the one that fixes with the adhesive tape or the one that is fixed with silcone ?? also the one that fits with silcone only expand 10 mm but still thats quite a lot more than nothing. which will stick better??
has anyone used this product any views
