We’ve a 2008, 2.0 (R20a) petrol CR-V with 190,000 on the clock.
It’s overheating - the bottom hose is cold and the radiator is cold at the bottom too. The top hose is hot.
I’ve:
changed the thermostat (no difference)
checked the old thermostat in hot water (it still worked)
removed the new thermostat and run the car with water and the bottom hose heated up
partially drained the system and added Wynns radiator flush - that produced some bits of rust when drained
On the initial drain of the system to change the thermostat I did notice a cloud of brown water. There’s also some deposits around the hose connectors and thermostat housing - it’s reasonably hard and crumbly - could it be limescale? The can hasn’t always had the correct antifreeze mix as it had a slight leak a few years back and (as it turns out) was only topped up with tap water.
Additionally, I replaced the radiator just over two years ago (because of the slight leak) and the system has been fine since.
Due to the mileage of the car, I didn’t want to take it to a garage but I’m fresh out of ideas - all thoughts gratefully received!
I’ve:
