my fathers honeywell 2 port valve recently croaked and so I got a replacement, apparently a direct replacement. However once fitted I realised that the action of the valve was completely different. e.g The old valve was closed by default and opened (allowing flow to rads) when live was applied to it, but now the new valve is open by default and closes when power is applied to it.
The system is governed by a randall 102 programmer which is basic in the design e.g On hot water setting the programmer sets the HW pin live (to boiler and pump) . On HW and heating setting the HW and the Heating pin are set live... boiler and pump live and then heating->2 port valve live, causing the port to open and then flow to rads is assured.
Now that the action of the valve has changed then the system does not work as intended e.g the port closes when power is applied rather than opens. Added to this is the room stat that acts as a breaker for the live circuit to the 2 port valve, when calling for heat the thermostat makes the live connection and the 2 port was then opened.
How can I fix this behavior? do i need a different programmer?
thanks
Nemo
thanks
Nemo
