HONEYWELL 3 PORT VALVE
11 Nov 2007
West Midlands
Is there any chance somebody could tell me what position the Honeywell 3 port valve should be in when heating is turned on. I have one side saying MAN OPEN and the othere side saying AUTO. It is a gravity fed heating system.
if you push the lever across to man from auto it will be loose have no resistance on it.
If i push it over to manual, which is very easy. How will this effect the way my heating works. Will the hot water come on still? Will the heating come on still?
the lever is only a means of open both ports when filling/emptying the system.
not an indicator of the position of the valve.
what are you getting at ? are you getting both heating/hw ?
The lver does not usually move when the valve is activated, unless it's fitted sideways, with auto above man, but it is fine to fit it this way.
I just put in on MAN OPEN before switching heating on and the lever jumps to halfway. When i put Hot water on you can't move lever at all.
Which model Honeywell 3-port valve do you have - V4073 or V4044?
There are Port markings (A, B, AB) on the brass valve body. Which port connects to the hot water cylinder - A or B?
Just don't understand why both come on when only one is selected. I will get back to you, someone in the bath at the moment
